300kHz Signal Generator
Source: InternetPublisher:公子李 Keywords: Signal generator Updated: 2024/07/23
As shown in the figure, it is a 300kHz signal generator. It is composed of VT1, T1, VD4 and related components to form a voltage-controlled oscillator. The voltage-controlled oscillator adopts LC collector tuning. VTl is an oscillator tube. The tuning circuit is composed of variable capacitance diode VD4, capacitors C3~C6 and the inductance of the 1~3 windings of the variable capacitance diode T1. The variable capacitance diode VD4 works in reverse bias, and the control voltage is added to the negative end to change its capacitance. The oscillation signal is output by the 6~7 windings of Tl. Among them, C6 is a frequency fine-tuning capacitor. VD3 stabilizes the working voltage of the oscillation stage, and the stable voltage is 6.8V±0.2V.
Component selection:
Transistor VT1: 3DG6C, β=65~85. Diodes VD1, VD2: 2CPl4, VD5: 2CK18. Zener diode VD3: 2CWl4. Varactor diode VD4: 2CC5. Resistors R1: 3.6k, R2: 3.3k, R3: 5.1k, R4: 510Ω, R5: 3.9k, R6: 3k, R7: 100k, all of which are RTX-0.125W. Capacitors Cl, C2: 5μF30V, C3: 51pFl00V, C4: 820pFl00V, C5: (optional during commissioning), C6: 20pF. Transformer T1: Model L22, A=100. L1-4: Φ0.29mm, 27 turns, L2-3: Φ0.29mm, 18 turns, L4-2: Φ0.29mm, 9 turns, L5-8: Φ0.29mm, 7 turns, L6-7: Φ0.29mm, 6 turns. L1-3=292μH, allowable error range: 0~10μH.
- Practical method of making RC sine wave oscillator
- Transistor Ringing Generator
- Frequency Detection and Signal Generator Made with LM567
- 70MHz crystal oscillator-----70MHZ crystal oscillator
- A simple and low-cost mosquito repellent circuit design
- How to use hysteresis in SPICE to reduce distortion in tape recordings
- 1MHz crystal calibrator
- Switched harmonic crystal oscillator
- Low cost second signal oscillator
- Variable start/stop ramp oscillator
- One-digit display timer circuit diagram
- Home appliance repair signal generator circuit
- IF signal generator circuit
- Signal generator circuit with small distortion
- Simple signal generator and tester circuit
- Simple multifunctional signal generator circuit
- high frequency signal generator
- Step wave signal generator circuit diagram
- Second signal generator homemade LED digital clock
- Universal signal generator circuit diagram
