Music logic test pen
Source: InternetPublisher:无人共我 Keywords: Logic Test Updated: 2025/10/21
The circuit is shown in the figure. It consists of a pair of complementary signal detection control tubes VT1 and VT2 and an 8-sound effect music integrated circuit HY-88. It uses a micro speaker to produce sound and judges the measured logic state according to different music.
Circuit Principle: The HY-88 is an 8-sound effect music integrated circuit packaged in a PCB (printed circuit board) package. It has eight trigger control terminals, S1 through S8. Low-level triggers activate, corresponding to eight animal sounds pre-stored in internal ROM (read-only memory): insects, crickets, frogs, cuckoos, cats, dogs, cows, and horse hooves. Adjusting oscillator resistor R4 changes the pitch of the sounds. The audio signal is amplified by VT3 and drives speaker BL for sound. VD1 and VD2 are step-down diodes, ensuring that the operating voltage between Vdd and Vss falls within the 2.5V to 4.5V range. The detection status of the logic pen is as follows: (1) When the probe T does not touch the circuit or detects "hanging", VT1 and VT2 are both cut off, and the trigger terminals s1 and s2 of IC are pulled up to "1" by R3 and R2 respectively, the IC does not work, and BL is silent; (2) When the probe T detects "0", VT1 is cut off, VT2 is turned on, s2 is "1", s1 is triggered by "0", and BL makes an insect sound; (3) When the probe T detects "1", VT1 is turned on, VT2 is cut off, S1 is "1", S2 is triggered by "0", and BL makes a cricket sound; (4) When the probe T detects the "CP" pulse, VT1 and VT2 are turned on in turn, s1 and S2 are triggered alternately, and BL produces both cricket and insect sounds.
- Digital remote thermometer
- Working Principle and Production of TV Scanning Demonstrator
- Using sub-milliohm resistors for current sensing has its advantages but also presents challenges
- The making of watermelon ripeness measuring instrument
- Two-wire and four-wire resistance measurements
- Popular Four-State Logic Level Detector
- Small capacitance measurement circuit
- Humidity measurement circuit with temperature compensation
- Production of Sweep Frequency Signal Source
- Capacitor detection and screening circuit composed of 555
- Bus door status detection circuit
- Computer power detection circuit
- Automatic charging detection circuit and indication circuit
- Simple phase detection circuit
- α-ray application detection circuit
- A5348 smoke alarm detection circuit - typical application
- Light detection circuit with output filter to reduce noise
- DC recovery light detection circuit that suppresses useless stable background light
- Differential light detection circuit
- Photodiode pollution gas detection circuit
京公网安备 11010802033920号
