One of the negative sequence current phase failure protection circuits
Source: InternetPublisher:jikai233 Keywords: Protection circuit phase failure protection BSP Updated: 2020/11/23
It is a phase failure protection circuit designed by taking advantage of the phenomenon that the negative sequence current increases sharply when one phase of the motor power supply is disconnected . Negative sequence current can be detected through a negative sequence current filter. This type of circuit requires that the magnetic flux in the transformer core is not saturated
, that is, the core cross-section is required to be large enough.
The circuit is shown in Figure 4-30. It consists of current
transformers TAi, TA2, resistors, R2 and capacitor
Cl.
When a phase of the power supply is missing, a negative sequence current
is generated . The negative sequence current filter has a voltage signal output,
the thyristor V is triggered to conduct, the contactor KM
coil is short-circuited, KM loses power and is released, and the motor
stops. .
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Servo motor pin diagram/working principle/application
- Tutorial on making your own remote-controlled robotic arm
- How to make a wheeled self-balancing robot using ultrasonic sensors
- An automated model railroad layout project using a microcontroller
- DC motor drive circuit composed of L293D
- Motor automatic cycle control circuit
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of a four-bit remote control component capable of remote reset
- Ultrasonic blind pathfinder circuit
- Inpatient pager circuit
- soil content measurement circuit
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Schiller oscillator circuit
- Crabo oscillator circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Power phase sequence display circuit
