NTC three-phase asynchronous motor protection circuit c
Source: InternetPublisher:狂妄火龙果 Keywords: NTC protection circuit three-phase asynchronous motor motor protection Updated: 2021/02/07
Semiconductor thermistors are embedded thermal protection components and are very sensitive to temperature. The temperature control error is ±5°C. It has high reliability
, small size (diameter is 3. Smm), easy installation, and easy to embed in the winding. Using it as a temperature sensing element can effectively reflect
the temperature of the motor winding. The thermistor is placed in the three-phase stator winding, close to the enameled wire, and fixed with epoxy resin. Thermistors
are divided into negative temperature coefficient thermistors ( NTC ) and positive temperature coefficient thermistors (PTC).
The circuit is shown in Figure 4-1. Figure 4-1 (b) and (c) only show the protection circuit and not the main circuit. They are both
a switching circuit consisting of a single tube amplifier.
Thermistor brother. ,R. . ,R. , you can choose RRC6 type or MF-15 type (lokfl, 20℃). This thermistor
is about lkfl at 100℃ and about 0.6k, Cl at 110℃.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- The meaning and importance of circuit protection, common types of circuit protection
- How to remotely control devices using ESP8266 and LPC2148
- Use your smartphone to turn on/off the power in your home
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Introduction to the internal structure of the Delta winding motor
- Perform surgery on the speaker protection circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor self-starting circuit
- Design and production of no-load automatic power-off device for household power supply
- Overview of 3.7v lithium battery protection board
- How the thermistor works
- Capacitive Neutral Leakage Protection Circuit
- Low voltage circuit breaker protection circuit e
- The structure and working principle diagram of various protection circuits a
- USB interface circuit of Newman MP4 machine
- PTC three-phase asynchronous motor protection circuit 8
- One of the PTC three-phase asynchronous motor protection circuits
- Double interlock control circuit of three-phase asynchronous motor
- Three-phase asynchronous motor forward and reverse manual control circuit
