Three-phase asynchronous motor forward and reverse manual control circuit
Source: InternetPublisher:天天都吃好吃的 Keywords: Three-phase asynchronous motor electric motor Updated: 2021/09/01
Circuit working principle: timer IC , together with inverter Ic3, form a bistable flip-flop
. When powered on, the output is low and the motor runs forward. If you press the switch SA. ,
the output becomes high level, and the motor runs in reverse direction. bistable flip-flop IC 2 and AND
gate IC. The two delay circuits are used to ensure that there is about a 5s gap time during the forward and reverse conversion process
to prevent short circuits when the current is switched; at the same time, the motor can be powered off first, and then the motor
can be started after the speed drops to reduce the starting current and Reverse impact, protect motor
and mechanical device.
- Tutorial on making your own remote-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- Introduction to the internal structure of the Delta winding motor
- Motor automatic cycle control circuit
- Using P110C to control 6 DC motors simultaneously
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of voice control circuit
- Water supply reminder after water outage
- Precious home appliance anti-theft alarm
- Multi-channel patrol detection control circuit b
- Flashing wall light control circuit
- Boiler control circuit
- Water dispenser double sheet control circuit
- PTC three-phase asynchronous motor protection circuit four
- NTC three-phase asynchronous motor protection circuit a
- Forward and reverse control circuit of three-phase asynchronous motor
- High current three-phase asynchronous motor Y conversion energy-saving control circuit_2
- Circuit diagram of a power-saving three-phase asynchronous motor phase failure protector
- Energy-saving three-phase asynchronous motor phase failure protection circuit
