Multi-unit slip motor synchronous operation speed control system circuit
Source: InternetPublisher:念慈菴 Keywords: Electric motor speed control system system circuit BSP Updated: 2020/01/17
The speed control system using the porcelain plate rheostat in the elastic frame-linked balance bridge for multi-unit synchronous adjustment
is shown in Figure 3-183. The speed control principles of other electromagnetic and photoelectric "elastic frames" are similar to this.
In the figure, BQ2 is the excitation winding of the main slip motor (that is, it is used as the speed reference), and BQi and BQ3
are the excitation windings of the slip motor in front of and behind the main slip motor respectively.
RPz is the master potentiometer, and adjusting it can change the speed of the entire system (ie, three slip motors). TGi~TG3
are three tachometer generators, which are connected to the electromagnetic clutch shafts of their respective slip motors. Adjusting the potentiometer 1RP1
(2RPi, 3RPl) can change the speed negative feedback voltage of each slip motor (which can cause the speed to change). lRP2
(2RP2, 3RP2) is a sensitivity potentiometer, which can be adjusted to change the speed of a corresponding slip motor. Porcelain disc varistor
RP. , RPb is used to coordinate the speed of three slip motors to make them run synchronously.
- Servo motor pin diagram/working principle/application
- Use your smartphone to turn on/off the power in your home
- An automated model railroad layout project using a microcontroller
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Add one more component to improve the phase failure protection function
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of voice control circuit
- Design and manufacture of three-phase motor protection circuit
- Infrared detection alarm
- Physiotherapy ventilator circuit
- Fish pond oxygenation reminder circuit
- Rice mill circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- AC voltmeter
- Parallel crystal oscillator
- Second-order active band-stop filter circuit
- Three primary color display circuit
- Fault signal trip circuit
- Sine wave signal generator circuit
