elleny
RHF43B Evaluation Board
EVAL-RHF43BV1
This data brief describes the EVAL-RHF43BV1 evaluation board.
This evaluation board is a ready-to-use, configurable hardware which allows designers to efficiently test a target device. A unique PCB is used in different configurations to support the radiation-hardened (rad-hard), operational amplifier devices.
This document shows the components incorporated on the EVAL-RHF43BV1 evaluation board and suggests several ways to use the board.
The EVAL-RHF43BV1 evaluation board is intended only for evaluation purposes.
Main features
  • Mounted Engineering Model RHF43BK1: Rad-hard, 8 MHz, operational amplifier (see RHF43B datasheet for further information)
  • Mounted components (ready-to-use)
  • Material: two-layered FR-4
  • PCB thickness: 1.6 mm
  • Copper thickness: 35 μm
  • Analog connections: SMA
  • Supply connections: banana 2 mm
Search Datasheet?
Forum More
Update:2025-08-07 02:56:32
