ghaytweyhtoo
SO8 packaged single-channel operational amplifier demonstration board
STEVAL-CCA036V1
The STEVAL-CCA036V1 demonstration board is designed to help characterize single operational amplifiers in SO8 packages.
With this board, the most common op-amp based circuits can be achieved.
The board is designed for surface-mounted components and can be used to perform onboard characterization prior to the integration of STMicroelectronics’ products in your designs. Resistor and capacitor footprints are implemented for the 0805 series. A set of two decoupling capacitors have been implemented on both power supply pins so as to benefit from the maximum performances of ST products. In order to reject a wide range of frequencies, 10 nF and 4.7 μF are good values for these capacitors.
Main features
  • This demonstration board with its components allow it to be configured as:
    • Low-pass Sallen-Key circuit
    • High-pass Sallen-Key circuit
    • Differential amplifier
    • AC-coupled circuit
    • In-loop compensation circuit
    • Out-of-loop compensation circuit
    • Numerous other possible configurations not described here
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 19:00:01
  • TI Designs: Launches 5 reference design materials for automotive electronics users, providing complete schematics/methods...
  • (Solved) Is LSM6DS3H or LSM6DSM used on SensorTile?
  • TI's latest DSP adds SATA and uPP, focusing on industry and communications
  • Help: STM8 stack overflow!!!
  • Electronics Technology Self-Study Method
  • Single package, small size drive motor controller is here
