newlandmark
VN7000AY Evaluation Board
EV-VN7000AY
EV-VN7000AY board provides you an easy way to connect STMicroelectronics® VIPower® M0-7 technology into your existing system.
Main features
  • Extreme low voltage operation for deep cold cranking applications (compliant with LV124, revision 2013)
  • General
    • Single channel smart high-side driver
    • Very low standby current
    • Compatible with 3 V and 5 V CMOS outputs
  • MultiSense diagnostic functions
    • Multiplexed analog feedback of: load current, VCC supply voltage and TCHIP device temperature
    • Overload and short to ground indication
    • Thermal shutdown indication
    • OFF-state open-load detection
    • Output short to VCC detection
    • Sense enable/disable
  • Protection
    • Undervoltage shutdown
    • Overvoltage clamp
    • Load current limitation
    • Latch-off on over temperature (ΔTJ_SD or TSD)
    • Loss of ground and loss of VCC
    • Reverse battery with self switch of the PowerMOS
    • Electrostatic discharge protection
Search Datasheet?
Forum More
Update:2025-07-20 17:59:22
