qoistoochee128
160 W + 160 W Dual BTL Class D Audio Amplifier Demonstration Board Based on TDA7498E
STEVAL-CCA044V1
The STEVAL-CCA044V1 demonstration board is designed for the TDA7498E high power dual BTL class-D audio amplifier.
Thanks to its high efficiency, the device assembled in the PSSO36 (slug-down) package is capable of dissipating heat without a heatsink.
Jumpers on the board allow the configuration of the amplifier in order to verify all the features as single-ended or differential input, fixed gain settings.
Microswitches are also provided to enable the standby and mute functions.
Main features
  • High output-power capability:
    • 2 x 160 W / 4 Ω at 36 V, 1 KHz, THD = 10%
    • 1 x 220 W / 4 Ω at 36 V, 1 KHz, THD = 10%
  • Wide-range, single supply operation (14 V- 36 V)
  • High efficiency (η = 85%)
  • Four selectable, fixed gain settings(23.6 dB, 29.6 dB,33.1 dB and 35.6 dB)
  • Differential inputs to minimize common-mode noise
  • Standby and mute features
  • Short-circuit and thermal overload protection
  • Externally synchronizable
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 06:20:06
