elleny
10 W + 10 WD Class Audio Amplifier Demonstration Board Based on TDA7491P
STEVAL-CCA028V1
The STEVAL-CCA028V1 demonstration board is designed for the TDA7491P high-power dual BTL class-D audio amplifier.
Thanks to its high efficiency, the device assembled in the PSSO36 (slug-down) package is capable of dissipating heat without any heatsink.
Jumpers on the board allow configuring the amplifier in order to verify all the features as single-ended or differential inputs, fixed gain settings.
Microswitches are also provided to enable the standby and mute functions.
Main features
  • 10 W +10 W continuous output power at THD = 10%, RL= 6 Ω, VCC = 11 V
  • 9.5 W + 9.5 W continuous output power at THD = 10%, RL= 8 Ω, VCC = 12 V
  • Wide-range single-supply operation (5-18 V)
  • High efficiency (η = 90 %)
  • Four selectable, fixed gain settings (20 dB, 26 dB, 30 dB and 32 dB)
  • Differential inputs to minimize common-mode noise
  • Filterless operation
  • Standby and mute features
  • Short-circuit and thermal overload protections
  • Externally synchronizable
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 12:15:14
