fish001
L5964 based digitally controlled DC-DC converter for automotive
AEK-POW-L5964V1
The AEK-POW-L5964V1 expansion board is designed for motor vehicle or truck body applications that require different voltages, such as USB-PD or infotainment systems. This product features two independent converters that can provide fixed or variable output voltages via MCU control. The output current of each channel is up to 3A.
The evaluation board contains monitoring circuitry for input and output voltages, as well as LEDs to indicate operating status. EMI can be minimized through appropriate filtering techniques.
The converter is based on the L5964 step-down switching regulator (buck topology) with over-current and over-temperature protection. L5964 integrates the control, power switch and monitoring circuits of two converters as well as watchdog, wake-up and reset functions.
The AEK-POW-L5964V1 expansion board is part of the AutoDevKit program. It plugs into the top of other boards via a 4x20 male/female connector that is compatible with the 4x37 MCU male connector on the SPC58EC-DISP or AEK-MCU-C4MLIT1 evaluation boards.
A demo application and an AutoDevKit component plug-in are also provided for the SPC5-STUDIO tool environment.
Main features
  • Dual-Channel Standalone Buck Regulator with Integrated Synchronous MOSFET
  • Output current up to 3 A per channel
  • Channels can be connected in parallel for higher current supply
  • Input voltage range: 6 to 14 V
  • Digitally selectable fixed output voltage: 3.3 - 5 - 9 V
  • PWM programmable output voltage in 20 mV steps from 3.3V to 11V
  • Output has short circuit and overcurrent protection
  • Input and output voltage monitors (UV or OV) and power good signal
  • Integrated thermal sensor provides thermal protection
  • Internal linear regulator provides additional 3.3 V output
  • Watchdog, reset, input/output synchronization available converters
  • Board size: 84.7 mm x 81.3 mm
  • Maximum component height: 10 mm
  • Automotive-compliant STMicroelectronics components
  • Included in AutoDevKit plan
  • Compliant with RoHS and Chinese version of RoHS standards
  • Passed WEEE certification
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 03:44:22
