smallembedded
L9963 Evaluation/Development Board: Used with external user MCUs for evaluation or development purposes
EVAL-L9963
The EVAL-L9963 is a hardware tool for evaluation of L9963, automotive chip for battery management applications. It can be used for the development of a 48 V battery management system (BMS) or as lower stage of a distributed BMS (depending on total battery voltage. Additional stages can be added thanks to EVAL-L9963-NDS).
An external MCU is necessary for development purpose. For L9963 evaluation EVAL-L9963-MCU is recommended. EVAL-L9963 allows the user to connect up to 14 channels for cell voltage sensing, one channel for current sensing, and up to 4 analog input for temperature sensing (plus an additional on-board NTC to sense PCB temperature). The board provides pin connector with relevant control signal (i.e. SPI) in order to help prototyping of a BMS based on EVAL-L9963 and an external MCU.
Main features
  • Pin connector for external MCU for FW development
  • Measures from 4 to 14 cells in series, with 0 us desynchronization delay between samples. Supports also busbar connection without altering cell results
  • Coulomb counter supporting pack overcurrent detection in both ignition on and off states
  • Fully synchronized current and voltage samples
  • 16-bit voltage measurement
  • 2.66 Mbps isolated serial communication with regenerative buffer, supporting dual access ring
  • Transformer based isolation
  • Up to 4 analog inputs for NTC sensing, plus PCB temperature sensing
  • Onboard L9001 regulator power supply.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 14:13:24
