newlandmark
L6360 based IO-Link master evaluation board with ST morpho connector for STM32 Nucleo
STEVAL-IOM001V1
The STEVAL-IOM001V1 evaluation board is based on the L6360 IO-Link master transceiver with physical layer compliant with IO-Link v1.1 specification.
Together with the STSW-IOM001 example code, it provides an affordable and easy-to-use solution for the development of IO-Link applications, letting you easily evaluate the communication features and robustness of the L6360.
You can also perform evaluation of multiple ports industrial IO-Link master modules by connecting up to four STEVAL-IOM001V1 with few solder bridge modifications.
The STEVAL-IOM001V1 interfaces with the STM32 Nucleo microcontroller via UART and GPIO pins and is compatible with the Arduino UNO R3 (optional configuration) and ST morpho (default configuration) connectors.
Main features
  • IO-Link master PHY based on L6360
  • Interrupt diagnostics pin
  • I²C and UART interface
  • SPI (slave) interface
  • 65 mA selectable (3.3 or 5.0 V) linear regulator
  • CQ (push-pull) and L+ (high side) switches
  • IQ additional IEC61131-2 type 1 digital input
  • L+ and CQ overload and overheating protections with non-dissipative cut-off function
  • QFN-26L (3.5x5x1 mm) package
  • Operating voltage range from 18 to 32.5 V
  • Additional high side switch for L+ heavy loads (IPS161H)
  • LEDs for status and diagnostics
  • Ground and VCC wire break protections
  • EMC compliance with IEC61000-4-2, IEC61000-4-3, IEC61000-4-5
  • Equipped with ST morpho connectors
  • CE certified
  • RoHS and China RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-13 03:17:27
  • 15-channel lithium battery management module
  • Recommended RF front-end chips for mobile phones in the 5G era
  • 【20-bit single-chip audio digital-to-analog converter PCM63P】
  • Detailed explanation of CMD file configuration of TMS320F2812
  • Send a wince QQ exchange group
  • Questions about the underlying driver?
