aytwartoofyoroo
Automotive Grade ESD Protection Evaluation Board
STEVAL-OET003V1
This demonstration tool is designed to provide an easy way to evaluate the robustness of ESD diodes developed for the automotive environment. It is based on a master-slave structure on the same board using two STM8AF528.
The microcontrollers communicate with each other via a communication loop based on LIN/CAN protocol. Communication flow status is indicated by four onboard LEDs. The LIN and CAN bus interfaces use four transceivers and are supplied by the step-up converter.
Main features
  • Input voltage 5 V
  • 12 V output, step-up converter for transceiver supply voltage
  • LIN transceiver
  • CAN transceiver
  • Automotive-grade ESD protection
  • IEC61000-4-2 compatibility
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 12:32:55
