ghaytweyhtoo
DiSEqC 1.X compatible dual LNB power and control IC based on LNBH26
STEVAL-CBL011V1
The STEVAL-CBL011V1 demonstration board implements a DC-DC converter based on ST’s LNBH26 device. It is used to power LNBs in dish antennas to receive satellite TV signals.
The LNBH26 is an integrated solution for supplying/interfacing satellite LNB modules in accordance with international standards.
This single device offers a complete solution for dual-tuner satellite receivers and provides good performance at low cost using a low external component count.
The LNBH26 demonstration board includes an I2C bus interface and a factory-trimmed internal 22 kHz tone generator which can be controlled through the DSQIN pin (TTL compatible). This allows immediate DiSEqC™ data encoding.
Thanks to a fully integrated step-up DC-DC converter, the STEVAL-CBL011V1 demonstration board can operate with a single input voltage supply source, ranging from 8 to 15 V.
Main features
  • Complete interface between LNB and I2C bus
  • Built-in DC-DC converter for single 12 V supply operation and high efficiency (typ. 93% @ 0.5 A)
  • Selectable output current limit by external resistor
  • Compliant with main satellite receiver output voltage specification (15 programmable levels)
  • Accurate built-in 22 kHz tone generator compliant with widely accepted standards
  • 22 kHz tone waveform integrity guaranteed also in no load condition
  • Low drop post regulator and high efficiency step-up PWM with integrated power N-MOS for low power loss
  • LPM (low power mode) function to reduce dissipation
  • Overload and overtemperature internal protection with I2C diagnostic bits
  • LNB short-circuit dynamic protection
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 15:19:06
  • AMIC 2.4G wireless transceiver chip
  • Next-generation wafer dicing technology
  • Have you bought your ticket home?
  • TMS320F28027 I2C
  • I would like to ask the master to answer this question again. How to adjust the linearity of this power supply?
  • How to fill copper foil
