Lemontree
Three-phase full parallel electric meter evaluation board based on STPMS2, STISO621W and STM32F413RH
EVALSTPM-3PHISO
The EVALSTPM-3PHISO evaluation board implements a complete three-phase energy meter with low-cost shunt current sensors.
The solution is based on the STPMS2 device, a double channel, 24-bits second order sigma-delta modulator, measuring voltage and current for each phase through a voltage divider and a shunt current sensor. Sensing circuitry and PCB layout are optimized to maximize signal-to-noise ratio for optimal accuracy.
The STPMS2 oversamples the signal using a 4 MHz clock distributed in a synchronized way by the microcontroller and outputs voltage and current sigma-delta bitstreams, multiplexed on the same pin.
The two-wire communication between STPMS2 modulator and MCU is isolated by STISO621W, 6 kV galvanic isolated interface, allowing up to 100 Mbps rate and low pulse distortion (<3ns) for safe and fast data transfer between isolated domains.
The FW embedded in the solution exploits the DFSDM filters of the STM32F413RH to convert the six bitstreams into 24-bits voltage and current data, at 200 us rate. All the metrology parameters are computed real time on a 200 us basis.
Two LEDs are available for active and reactive pulses generation.
The FW also implements a virtual com port communication to easily access the internal parameters to read metrology data, to modify the internal configuration for a high flexibility of the application, and to calibrate the board.
Main features
  • Compliant to EN 50470-x, IEC 62053-2x, ANSI12.2x standard requirements for AC watt meters
  • Active wideband, active fundamental, reactive and apparent power/energy calculation for each phase and cumulative
  • Accuracy Class 0.5 according to IEC 62053-22 on 3-ph active/apparent power measurement
  • Accuracy Class 1 according to IEC 62053-21 on 3-ph reactive power measurement
  • 6 channels voltage and current decimated samples available @200 us
  • 5 kHz measurement bandwidth
  • RMS and THD (optional) calculation of each voltage and current signal
  • Selectable high pass filter for DC measurement
  • Line period and phase shift measurement for each phase
  • Phase voltage delays
  • Full calibration (amplitude, power offset and samples offset for DC measurement)
  • Two configurable LED for pulsed outputs
  • Communication through USB in virtual com port mode with shell commands
  • 6 kV galvanic isolation between the phases with 8 mm creepage and clearance
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 00:55:30
  • Output Capacitor
  • Use of Makefile Tool
  • DIY diamond ring with nuts
  • 【MicroPython】STM32L476 version of Pyboard
  • Altium Designer PCB Design Tutorial Super Detailed
  • DSP-Beginning
