smallembedded
Evaluation board based on HVLED815: 8W European range high power factor LED driver with primary constant voltage regulation
EVLHVLED815W8CV
The LED demonstration board is based on a high power factor flyback topology using the STMicroelectronics®HVLED815PF device.
The HVLED815PF is a high-voltage primary switcher intended for operating directly from the rectified mains with minimum external parts and enabling high power factor (> 0.90) to provide an efficient, compact and cost effective solution for LED driving. It combines a high-performance low voltage PWM controller chip and an 800 V, avalanche-rugged Power MOSFET, in the same package. There is no need for the optocoupler thanks to the patented primary sensing regulation (PSR) technique.
Main features
  • 8 W LED driver - constant voltage
  • EU range input (200 - 265 Vac)
  • Isolated solution
  • Single stage HPF flyback
  • Primary side regulation - no optocoupler
  • Power factor > 0.90
  • LED driver efficiency > 87%
  • Harmonics distortion meets EC 61000-3-2 Class D
Search Datasheet?
Forum More
Update:2025-07-22 20:44:15
