smallembedded
HB LED driver, based on ST1CC40 in QFN package, with disable function
STEVAL-ILL046V1
The STEVAL-ILL046V1 evaluation board is based on the ST1CC40, which is an 850 kHz fixed switching frequency monolithic step-down DC-DC converter designed to operate as a precise constant current source with an adjustable current capability of up to 3 A DC.
In closed loop operation, the ST1CC40 feedback pin voltage is 100 mV thus the sensing resistor calculation is expressed as Rs = 100 mV/ILED.
The STEVAL-ILL046V1 is provided with 660 mA by connecting a 150 mW sensing resistor to the feedback pin.
The overall application size is minimized, thanks to the high switching frequency and ceramic output capacitor compatibility.
The STEVAL-ILL046V1 evaluation board is fully protected against overheating, overcurrent and output short-circuit.
The inhibit mode minimizes the current consumption in standby (6 µA) to maximize battery life in portable devices.
Main features
  • 3 to 18 V operating input voltage range
  • 850 kHz fixed switching frequency
  • 100 mV (typ) current sense voltage drop
  • 6 µA standby current in inhibit mode
  • ±7% output current accuracy
  • Synchronous rectification
  • Embedded compensation network
  • Internal current limiting
  • Ceramic output capacitor compliant
  • Thermal shutdown
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 18:13:41
