newrudeman
80 W offline PFC and LED driver demonstration board with dimming based on L6562A
STEVAL-ILL013V1
The use of high power LEDs in lighting applications is becoming increasingly popular due to rapid improvements in lighting efficiency, longer life, higher reliability and overall cost effectiveness. Dimming funtions are more easily implemented in LEDs, and they are more robust and offer wider design flexibility compared to other light sources.
The STEVAL-ILL013V1 demonstration board is an 80 W offline dimmable LED driver with high power factor (PF) intended for 350 mA, 700 mA and 1 A LEDs.
The converter is designed as a constant current source to achieve the best lighting performance from the LEDs, and can be used for lighting applications from low power, low voltage to high power, high voltage. This allows designers to cover a wide range of different LED systems using a single topology.
Additionally, in lighting applications where the input active power is higher than 25 W and a high power factor is required, the high PF converter can be connected as the first stage, before the modified BUCK converter.
This demonstration board design is complaint with standard EN61000-3-2 (limits for harmonic current emissions).
Main features
  • EN55015 and EN61000-3-2 compliant
  • EMI filter implemented
  • Non-isolated SMPS
  • Universal PWM input for dimming (external board required)
  • 80 W LED driver
  • High efficiency (~90%)
  • 350 mA, 700 mA and 1 A LED current settings
  • High power factor: 0.982 for 230 V/50 Hz AC
  • Brightness regulation between 0 and 100%
  • Wide input voltage range: 88 V to 265 VAC
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:37:16
  • Compile error under ARM9 development board PB
  • MCU needs improvement
  • TI's new automotive linear LED driver TPS92613-Q1 with enhanced heat dissipation
  • Laser ranging sensor parameters
  • MSP430 FFT Algorithm
  • PCB Layout Fundamentals
