elleny
Power over Ethernet (PoE) powered 45 W LED driver control reference design with Bluetooth Low Energy (BLE)
STEVAL-POEL45W1
The STEVAL–POEL45W1 Power over Ethernet (PoE) powered LED driver reference design delivers a power output of 45 W and dims LEDs down to 1% of the maximum brightness without any flicker. The solution supports remote dimming control via Bluetooth with the PoE_Lighting Android application (available on Google Play).
You can use this reference design to develop complete indoor network-powered lighting solutions with IP-based Powered Devices (PDs), without additional AC power infrastructure, and extend the functionality to include remote data management via existing LAN networks.
The reference design features a highly integrated PM8805 IEEE802.3bt-compliant Powered Device (PD) PoE interface, a high efficiency LED6000 LED driver able to source up to 3 ADC current, and a certified SPBTLE-1S Bluetooth Low Energy module, compliant with BT specifications v4.2 and BQE qualified.
The STSW-POEL45FW board firmware is programmed via the STSW-BNRG1STLINK utility.
Main features
  • PoE-PD IEEE 802.3af/at/bt compliant
  • Constant current output, working in buck topology
  • Output current – 1.4 A with
  • Number of LEDs connected at output: 6 – 11 white LEDs (3.3 V each)
  • Wireless ON/OFF and dimming control with PoE_Lighting Android application
  • Digital dimming with 1% resolution
  • LED driver input voltage range 37 – 57 VDC
    • Peak efficiency at maximum load > 95%
    • Low standby power consumption
    • Comprehensive set of protections:
      • open/no-load circuit protection
      • short/overload circuit protection
    • RoHS compliant
    • WEEE compliant
    参考设计图片
    Search Datasheet?
    Forum More
    Update:2025-08-08 23:22:29
