ghaytweyhtoo
300 W Motor Control Power Board Based on STGIPNS3H60T-H SLLIMM™-Nano SMD IPM MOSFET
STEVAL-IPMNG3S
The STEVAL-IPMnG3S is a compact motor drive power board based on SLLIMM™-nano SMD (small low-loss intelligent molded module) product ( STGIPNS3H60T-H). It provides an affordable and easy-to-use solution for driving high power motors in a wide range of applications such as power white goods, air conditioning, compressors, power fans and 3-phase inverters for motor drives in general.
The IPM itself consists of short-circuit rugged IGBTs and a wide range of features like undervoltage lockout, smart shutdown, internal temperature sensor and NTC, overcurrent protection and internal op-amp.
The main characteristics of this evaluation board are small size, minimal BOM and high efficiency. It features an interface circuit (BUS and VCC connectors), bootstrap capacitors, snubber capacitor, hardware short-circuit protection, fault event signal and temperature monitoring. It is designed to work in single- or three-shunt configuration and with triple current sensing options: three dedicated on-board op-amps, op-amps embedded on MCU or single internal IPM op-amp. The Hall/Encoder part completes the circuit.
The system is designed to achieve accurate and fast conditioning of current feedback to satisfy the typical requirements for field oriented control (FOC).
The STEVAL-IPMnG3S is compatible with ST’s control board based on STM32, providing a complete platform for motor control.
Main features
  • Input voltage: from 125 to 400 VDC
  • Nominal power: up to 300 W
  • Nominal current: up to 1.8 A
  • Input auxiliary voltage: up to 20 VDC
  • Single- or three-shunt resistors for current sensing (with sensing network)
  • Three options for current sensing: dedicated external op-amps, internal SLLIMM-nano op-amp (single) or via MCU
  • Overcurrent hardware protection
  • IPM temperature monitoring and protection
  • Hall sensor or encoder input
  • IGBT intelligent power module:
    • SLLIMM-nano IPM (STGIPNS3H60T-H) - SMD package
  • Motor control connector (32 pins) interfacing with ST MCU boards
  • Universal design for further evaluation withbread board and testing pins
  • Very compact size
  • WEEE compliant
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-18 22:52:33
  • 2006 Guangxi University Student Electronic Design Competition Topic
  • Looking for a job...
  • Altium compilation error
  • Nucleo experience + the tangled process of building an environment platform
  • Ask about the computing speed of MSP430
  • 【Baby Show】My little baby
