supremeOne
L6205 DMOS dual full-bridge driver evaluation board
EVAL6205N
The EVAL6205N will help you in evaluating the L6205 in PowerDIP package. It implements a typical application, enabled to run one to four DC motors or one stepper motor. On the board the L6506, PWM current controller, provides the current control for the L6205N power section. Screw connectors provide connection to motor supply rail and 5 V reference for the logic inputs, as well as the four outputs to motor windings. EVAL6205N can be hooked-up to practiSPIN interface board (EVALpractiSPIN) through a 34-pin connector. This also gives direct access to ICs input signals as well as making possible to provide reference voltages for current control PWM. Operating frequency and reference voltage (independent for the two channels) for the L6506 PWM current control loops could be set by means of three pots placed on the board. EVAL6205N can be used as well to evaluate the L6225N product just adjusting pot settings.
Main features
  • UNDER VOLTAGE LOCKOUT
  • THERMAL SHUTDOWN
  • INTEGRATED FAST FREE WHEELING DIODES
  • PARALLELED OPERATION
  • PROTECTION
  • OPERATING SUPPLY VOLTAGE FROM 8 TO 52V
  • RDS(ON) 0.3W TYP. VALUE @ Tj = 25 °C
  • 5.6A OUTPUT PEAK CURRENT (2.8A DC)
  • NON DISSIPATIVE OVERCURRENT
  • CROSS CONDUCTION PROTECTION
  • OPERATING FREQUENCY UP TO 100KHz
Search Datasheet?
Forum More
Update:2025-08-08 15:49:54
