aytwartoofyoroo
High voltage evaluation board for PWD13F60
EVALPWD13F60
The PWD13F60 is a high density power driver integrating gate drivers and four N-channel power MOSFETs in dual half-bridge configuration.
The integrated power MOSFETs have a low RDS(on) of 320 mΩ and 600 V drain-source breakdown voltage, while the embedded gate drivers high-side can be easily supplied by the integrated bootstrap diode. The high integration of the device allows loads in a tiny space to be driven efficiently.
The PWD13F60 accepts a supply voltage (VCC) extending over a wide range and is protected by a low voltage UVLO detection on the supply voltage.
The input pin extended range allows easy interfacing with microcontrollers, DSP units or Hall effect sensors.
The EVALPWD13F60 is 48 x 53 mm wide, FR-4 PCB resulting in an Rth(J-A) of 18 °C/W, capable to drive loads up to 2 ARMS, without forced airflow cooling.
Both controlling and power signals are available on pin strip for easy connection to customer's board.
Main features
  • Power system-in-package integrating gate drivers and high-voltage power MOSFETs:
    • Low RDS(on) = 320 mΩ
    • BVDSS = 600 V
  • Suitable for operating as:
    • Full-bridge
    • Dual independent half-bridges
  • Wide input supply voltage down to 6.5 V
  • UVLO protection on supply voltage
  • 3.3 V to 15 V compatible inputs with hysteresis and pull-down
  • Interlocking function to prevent cross conduction
  • Internal bootstrap diodes
  • QFN (10x13 mm) package
  • Very compact layout
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 21:39:29
  • Design of information processing and monitoring system for modern elevators
  • CC2530 wireless lighting experiment
  • About Kalman Filter Algorithm
  • Very good DSP introductory material (I)
  • Fortune China: The Secret of Huawei
  • Frequency Response of an RC Low Pass Circuit
