qoistoochee128
High-end driver based on L6370Q
STEVAL-IFP020V1
The STEVAL-IFP020V1 demonstration board is based on the L6370Q, a single-channel high-side driver chip intended for driving resistive, inductive or capacitive loads in an industrial environment. It provides an embedded fast demagnetization feature for inductive load switch-off.
The device evaluates load disconnection (during channel on-state), output short to VCCor GND, overtemperature, undervoltage of supply voltage, and provides feedback to a control unit.
Integrating an extensive set of electrical protections makes the application safe and reliable for use in harsh conditions.
The STEVAL-IFP020V1 demonstration board is an example of application design using the L6370Q. It is used to guide the designer in choosing external components for applications while providing an appropriate PCB design.
Main features
  • Single-channel topology
  • Galvanic isolation
  • 2.5 A output current
  • 9.5 V to 35 V supply voltage range
  • Short-circuit, overload, and thermal protections
  • Loss of ground and VSprotections
  • Fast demagnetization of inductive loads
  • Open load, output short to VSdetection
  • Two diagnostic outputs
  • Output status LED driver
  • EMC immunity against burst, surge, and ESD
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 10:55:39
