Lemontree
L6564 Transition Mode PFC (Power Factor Correction) Evaluation Board
EVL6564-100W
The EVL6564-100W demonstration board implements a 100 W power factor correction (PFC) pre-regulator, continuous power, on a regulated 400 V rail from a wide range mains voltage and provides for the reduction of the mains harmonics, which allows meeting the European EN61000-3-2 or the Japanese JEITA-MITI standard. The regulated output voltage is typically the input for the cascaded isolated DC-DC converter that provides the output rails required by the load.
The board is designed to allow full-load operation in still air.
Main features
  • PCB type and size: Single-side, 35 µm, CEM-1, 90 x 83 mm
  • Maximum ambient temperature: 50 °C
  • Minimum switching frequency: 40 kHz
  • Hold-up time: 10 ms (VDROP after hold-up time is 300 V)
  • Line voltage range: 90 to 265 Vac
  • Regulated output voltage: 400 V
  • Minimum line frequency (fL): 47 Hz
  • Maximum 2 fL output voltage ripple: 20 V peak-to-peak
  • Minimum estimated efficiency 92% (at Vin = 90 Vac, Pout = 100 W)
  • Rated output power: 100 W
Search Datasheet?
Forum More
Update:2025-08-05 03:53:09
