toothache
3A/1.5MHz step-down synchronous switching regulator based on ST1S31 in DFN 3x3 package
STEVAL-ISA069V1
The STEVAL-ISA069V1 demonstration board is based on the ST1S31, which is an internally compensated 1.5 MHz fixed-frequency PWM synchronous step-down regulator. This device operates from 2.8 V to 5.5 V input, while it regulates an output voltage as low as 0.8 V and up to Vin.
The peak current mode control with internal compensation delivers a very compact solution with a minimum component count.
Main features
  • 4 A peak output current
  • From 2.8 V to 5.5 V input voltage
  • Output voltage adjustable from 0.8 V
  • 1.5 MHz switching frequency
  • Internal soft-start and enable
  • Integrated 60 mΩ and 45 mΩ power MOSFETs
  • All ceramic capacitors
  • Power Good (POR)
  • Cycle-by-cycle current limiting
  • Current foldback short-circuit protection
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 12:14:21
