JFET
2A buck switch demonstration board based on L7980
STEVAL-ISA092V1
The STEVAL-ISA092V1 is a step-down switching power supply based on the L7980 in a QFN package.
The L7980 is a step-down switching regulator with embedded Power MOSFET, so it is able to deliver up to 2 A current to the load depending on the application conditions.
The input voltage can range from 4.5 V to 28 V, while the output voltage can be set starting from 0.6 V to VIN.
Requiring a minimum set of external components, the device includes an internal 250 kHz switching frequency oscillator that can be externally adjusted up to 1 MHz.
Main features
  • 2 A DC output current
  • 4.5 V to 28 V input voltage
  • Output voltage: 3.3 V (adjustable from 0.6 V)
  • 250 kHz switching frequency, programmable up to 1 MHz
  • Internal soft-start and enable
  • Low dropout operation: 100% duty cycle
  • Voltage feed-forward
  • Zero load current operation
  • Overcurrent and thermal protection
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-13 23:47:40
