containsmachine
3A step-down switching power supply demonstration board based on L7981 (QFN)
STEVAL-ISA093V1
The STEVAL-ISA093V1 is a step-down switching power supply based on STMicroelectronics’ L7981 switching regulator in a QFN package.
The L7981 features an embedded power MOSFET and is capable of delivering up to 3 A of current to the load, depending on the application conditions.
The input voltage can range from 4.5 V to 28 V, while the output voltage can be set from 0.6 V to VIN.
Requiring a minimum number of external components, the device includes an internal 250 kHz switching frequency oscillator that can be externally adjusted up to 1 MHz.
Main features
  • 3 A DC output current
  • 4.5 V to 28 V input voltage
  • Output voltage adjustable from 0.6 V
  • 250 kHz switching frequency, programmable up to 1 MHz
  • Internal soft-start and enable
  • Low dropout operation: 100% duty cycle
  • Voltage feed-forward
  • Zero load current operation
  • Overcurrent and thermal protection
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-04 02:01:23
  • Oscilloscope V2.0 assembly and debugging (flt9006) VOL.1----Repair the board
  • About the serial communication problem between two microcontrollers
  • The circuit board makes abnormal noise
  • Amplify voltage
  • Does gcc support stm8
  • This week's highlights
