supremeOne
4A, 850kHz fixed frequency PWM synchronous buck demonstration board based on ST1S41
STEVAL-ISA108V1
Based on the ST1S41 step-down switching regulator, the STEVAL-ISA108V1 demonstration board is an internally-compensated 850 kHz fixed-frequency PWM synchronous step-down converter.
The ST1S41 operates from 4.0 V to 18 V input, while it regulates an output voltage as low as 0.8 V and up to VIN(100% duty cycle).
The ST1S41 integrates a 95 mΩ high side switch and 69 mΩ low side synchronous rectifier, resulting in very high efficiency with very low output voltages.
The peak current mode control with internal compensation offers a compact solution with a minimum component count.
Main features
  • 4 to 18 V input voltage
  • Output voltage adjustable from 0.8 V
  • 850 kHz switching frequency
  • Internal soft-start
  • Integrated 95 mΩ and 69 mΩ power MOSFETs
  • All ceramic capacitor
  • Enable function
  • Cycle-by-cycle current limiting
  • Current fold-back short-circuit protection
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:36:32
