supremeOne
Power over Ethernet - IEEE 802.3af compliant PD converter with 3.3V, 3A output
STEVAL-TSP006V2
This document focuses on a reference design for a simple, low cost 3.3 V 3 A flyback converter based on the PM8800A device.
The PM8800A is a highly integrated device embedding an IEEE 802.3af compliant “Powered Device” (PD) interface together with a PWM controller.
It can be successfully used in all low power, low cost PoE applications.
Main features
  • IEEE 802.3af compliant PD interface
  • Works with power supplied from Ethernet LAN cables or from local auxiliary sources
  • Line input voltage range: 40 Vdc to 60 Vdc, output voltage: 3.3 Vdc ± 5%
  • Output current: 3 A
  • Peak-to-peak output ripple: 30 mV
  • Efficiency DC-DC full-load: > 83%
  • Efficiency overall peak: > 80%
  • Transient response ΔVoutpk-pkto 50% load step: pp
  • ΔV in load line case:
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 02:56:53
