TEL13699758578
Design a TYPEC to HDMI2.0 4K60Hz screen projection converter using CS5265
How to find a TYPEC to HDMI2.0 4K60Hz screen converter? We only need a single CS5265 to design this converter. Below we describe in detail the CS5265 chip overview, CS5265 parameter characteristics, CS5265 pin configuration, CS5265 pin description, CS5265 design principle and PCB design files.
CS5265 is an audio and video conversion solution converter that converts USB TYPE-C to HDMI data. Supporting USB Type-C display port alternate mode, the CS5265 can transmit video and audio streams from the USB Type-C interface to the HDMI port. In CS5265, the displayPort v1.4 receiver supports 1.62Gbps, 2.7Gbps and 5.4Gbps frequency input in different configurations of 1 and 2 LAN. HDMI supports 4K 2K 60Hz frequency output. At the same time, the CS5265 chip can easily convert and encrypt type-c audio and video signals. Forms and procedures are documented using the CS5265 application. The HDMI transmitter contains an HDCP engine that supports HDCP1.4 and HDCP2.3. Thanks to the inclusion of HDCP, the CS5265 allows secure transmission of protected content. Embedded keys provide the highest level of HDCP key security.
CS5265 design type-c screen projection or type-cz to HDMI4K60HZ converter characteristic parameters are as follows:
Embedded 16-bit MCU
Supports HDCP 1.4 and HDCP2.3, with on-chip key to support HDCP repeaters.
Supports EDID and MCC passthrough
Support hot plug detection
CS5265 supports embedded MCU and SPI-flash
Supports embedded HDCP 1.4
Integrated 3.3V LDO and 1.8VL
Embedded 5V/1.2V high-efficiency voltage regulator
Simultaneous display via HDMI output
2KV ESD performance
Supports downlink spread spectrum clock (SSC)
The detailed design reference circuit, design PCB files, and design specifications of CS5265 are in the attachment below.
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-14 14:42:21
  • High salary looking for WINCE experts
  • EEWORLD University - Introduction to Computer Science and Programming
  • 【Atmel SAM D21】ADXL345 three-axis acceleration application
  • Cameras used in embedded systems
  • Electrical Engineering (Electronic Technology) Test Bank
  • Looking for part-time job,
