JFET
Automotive Dashboard Indicator Driver Reference Design
TIDA-00278
This TI reference design is an automotive dashboard signaling solution that contains a monolithic, medium voltage, low current power 12-bit shift register designed specifically for use in systems requiring relatively moderate load power, such as LEDs in car dashboards. This design is part of a complete automotive dashboard system solution optimized for the mid-range dashboard market. The entire solution supports 4.5-40V system functionality and can withstand cold crank, start-stop and load dump conditions.
characteristic
  • ● Wide input voltage range: 4.5V - 40V, can withstand start/stop, cold start and load dump conditions
  • ● The small and accurate Rdson of the internal MOSFET enables lower heat dissipation through the LED and more accurate output current
  • ● Slow switching speed: rise time = 207ns, fall time = 128ns, which obviously helps reduce EMI
  • ● Thermal shutdown protection helps avoid overheating and damage to the TLC6C5912-Q1
Backlog Impt notice changes Backlog Impt notice changes end
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-06 23:02:55
