supremeOne
Three-phase inverter based on STSPIN32F0601
EVSPIN32F06Q1S1
The EVSPIN32F06Q1S1 board is a 3-phase complete inverter based on the STSPIN32F0601 controller, which embeds a 3‑phase 600 V gate driver and a Cortex®-M0 STM32 MCU. The power stage features STGD6M65DF2 IGBTs, but can be populated with any IGBT or Power MOSFET in DPAK or powerFLAT 8x8 HV package.
The board has a single-shunt sensing topology, and both FOC and 6‑step control algorithms in either sensored or sensorless mode can be implemented. This allows driving permanent magnet synchronous motors (PMSMs) and brushless DC (BLDC) motors.
The evaluation board is compatible with a wide range input voltage from 35 VAC (50 VDC) to 280 VAC (400 VDC), and includes a power supply stage with the VIPER06XS in flyback configuration to generate +15 V and +3.3 V supply voltage required by the application.
Debug and configuration of FW can be performed with standard STM32 tools through the detachable STLINK‑debugger. SWD and UART TX‑RX connectors are also available.
主要特性
Input voltage from 35 VAC (50 VDC) to 280 VAC (400 VDC)
STGD6M65DF2 IGBTs power stage featuring:
V(BR)CES = 650 V
VCE(sat) = 1.55 V @ IC = 6 A
Overcurrent threshold set to 5.5 Apeak
Dual footprint for IGBT/MOSFET package:
DPAK
PowerFlat 8x8 HV
Single-shunt current sensing, suitable for:
Sensored or sensorless 6-step algorithm
Sensored or sensorless single-shunt vector (FOC) algorithm
Smart shutdown overcurrent protection
Digital Hall sensors and encoder input
Bus voltage sensing
15 V VCC and 3.3 V VDD supplies
Embedded ST-LINK/V2-1
Easy user interface with buttons and trimmer
RoHS compliant
Search Datasheet?
Forum More
Update:2025-07-19 20:15:16
