Lemontree
Three-phase inverter based on STSPIN32F0251
EVSPIN32F02Q1S1
The EVSPIN32F02Q1S1 board is a 3-phase complete inverter based on the STSPIN32F0251 controller, which embeds a 3‑phase 250 V gate driver and a Cortex®-M0 STM32 MCU. The power stage features STD17NF25 MOSFETS, but can be populated with any IGBT or Power MOSFET in DPAK or powerFLAT 6x5 package.
The board has a single-shunt sensing topology, and both sensored and sensorless FOC and 6‑step control algorithms can be implemented. This allows driving permanent magnet synchronous motors (PMSMs) and brushless DC (BLDC) motors.
The evaluation board is compatible with a wide range input voltage from 15 VAC (20 VDC) to 120 VAC (170 VDC), and includes a power supply stage with the VIPER013BLS in buck configuration to generate +15 V and +3.3 V supply voltage required by the application.
Debug and configuration of FW can be performed with standard STM32 tools through the detachable ST-LINK‑debugger. SWD and UART TX‑RX connectors are also available.
主要特性
Input voltage from 15 VAC (20 VDC) to 120 VAC (170 VDC)
STD17NF25 MOS power stage featuring:
V(DS) = 250 V
RDS(on) max. = 0.165 Ω
Overcurrent threshold set to 16 Apeak
Dual footprint for IGBT/MOSFET package:
DPAK
PowerFlat 6x5
Single-shunt current sensing, suitable for:
Sensored or sensorless 6-step algorithm
Sensored or sensorless single-shunt vector (FOC) algorithm
Smart shutdown overcurrent protection
Digital Hall sensors and encoder input
Bus voltage sensing
15 V VCC and 3.3 V VDD supplies
Embedded ST-LINK/V2-1
Easy user interface with buttons and trimmer
RoHS compliant
Search Datasheet?
Forum More
Update:2025-08-08 15:02:33
  • Ultrasonic alarm data download
  • WinCE 5.0 2440 crashes when waking up
  • Lithium battery charging problem
  • Sleeping taboo
  • Detailed Explanation of Embedded Linux Application Development
  • Regarding the problem of variables in pic, the value of the variable suddenly changed
