supremeOne
Digital capacitance meter made with AT89C2051 microcontroller
As a simplified version of AT89C51, AT89C2051 removes P0, P2 and other ports, reducing the number of I/O ports. However, it adds a voltage comparator, so its functions are enhanced in some aspects. For example, it can be used to process analog Quantity, simple analog-to-digital conversion, etc. This article uses this function to design a digital capacitance meter, which can measure the capacity of capacitors with a capacity less than 2 microfarads. It uses a 3-and-a-half-digit digital display. The maximum display value is 1999. The reading unit is uniformly nanofarads (nf), and the measuring range is divided into In the fourth gear, the readings are multiplied by the corresponding magnification.
Search Datasheet?
Forum More
Update:2025-08-08 23:22:06
