宋元浩
Evaluation board based on ST1PS02CQTR 400 mA nanostatic synchronous buck converter with AUX switch
Evaluation board based on ST1PS02CQTR 400 mA nano-quiescent synchronous step-down converter with AUX switch
The STEVAL-1PS02C evaluation board allows evaluation of a smart converter design able to deliver up to 400 mA output current from a 1.8 to 5.5 V input, with a dynamically adjustable 2.6 to 3.3 V output voltage.
[STEVAL-1PS02C IMAGE]
The board embeds the ST1PS02CQTR nano-quiescent miniaturized synchronous step-down converter which implements enhanced peak current control (PCC) and advanced design circuitry to minimize quiescent current. It features a controlled load switch to supply a subsystem with the same voltage rail. The device is supplied in TQFN12 (2.0x1.7 mm) thin package, but other packages are also available.
The board demonstrates how highly efficient conversion can be achieved using just the ST1PS02CQTR, a 2.2 μH inductor and two small capacitors.
The board highlights ST1PS02CQTR key application benefits, including high efficiency and small PCB size and thickness, and is ideal for power conversion solutions in wearable applications, fitness accessories, personal tracking monitors, smart watches, sports bands, energy harvesting, wireless sensors, industrial sensors, portable low power devices, single cell Li-Ion battery applications and Bluetooth® low energy and Zigbee applications.
所有功能
1.8 to 5.5 V input operating range
Up to 400 mA output current capability
Tiny external components: L = 2.2 µH typ.
Dynamically selectable output voltages from 2.6 to 3.3 V
Output voltage power good
Auxiliary load switch Vout2 (AUX control input)
WEEE and RoHS compliant (hardware only)
Search Datasheet?
Forum More
Update:2025-08-08 21:09:13
  • Help, driver software for Century Wind 628
  • This mini motorcycle is so cool!
  • Dynamic SHOW of various motor principles
  • Show off your gifts, Xiaomi Internet Radio
  • RS485 first experience TI SN75176BP
  • TI's clock enable function is locked when using ROM type chips
