aPeF7
IoT clock——1492056A
Project Description
Design an Internet of Things clock based on the esp-c3-12f wifi module.
Project function introduction
For reference , the link is attached below [ Internet of Things] IoT clock based on ESP32 - Easy EDA open source hardware platform (oshwhub.com) .
Project properties
Here you can fill in the completion progress bar of the project, select the check box according to the completed function, and also display the completion progress of the function.
  • [x] Schematic design
  • [x] PCB diagram design
  • [x] PCB proofing
  • [x] Welding test
  • [x] Functional testing
  • [x] Program testing
Function introduction and demonstration:
Connect to WiFi through WeChat and get the time through the network 1. Search on WeChat - Anxinke Technology - enter the official account - WeChat configuration - enter the wifi password - configure the network 2. Press and hold the key1 key for 10 seconds at the same time to enter the network configuration mode . Manually set the time as follows: 1. Press and hold key1 for 3 seconds to enter the time setting and set hours, minutes, and seconds respectively. 2. Press key1 to switch the set hours, minutes or seconds. 3. Press keys key3 and key2 to add and subtract time respectively.
Demo video
Precautions
1. Don’t use a large blade when soldering. It’s easy to scrape off the solder mask/(ㄒoㄒ)/~~ 2. The USB interface must be soldered firmly, otherwise it will fall off. 2. When welding, be sure to check whether there is a short circuit or a weak solder.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:22:20
