JFET
USB powered touch dimmer light
A USB powered lighting fill light. Plan to use 4 28mm LED filaments with dual color temperatures.
Fusion RH6616 single chip touch dimming is used. The small square copper paved area on the logo surface is the touch sensing area.
LED filament is not sold in Lichuang Mall, you need to buy it yourself on Taobao. The parameters are 26mm, 3V, 100mA. Color temperature can be selected as needed.
external link
https://www.irongu.cn/2020/04/22/usb powered touch dimmer light/
PCB description
There are two PCBs, one is the motherboard and the other is the reflective backplate. Not soldering the reflective backplate will not affect the circuit function, but when the light is turned on, the omnidirectional lighting may blind oneself.
Welding instructions
MOD foot settings
No. model M2 M1 dog Press
1 Stepless dimming function without brightness memory Air welding Air welding switch Stepless dimming
2 Stepless dimming function without brightness memory. Air welding Short switch Stepless dimming
3 Stepless dimming function with brightness memory and gradual brightening and dimming Short Air welding switch Stepless dimming
4 Three levels of dimming Short Short 3 levels of dimming 3 levels of dimming
If the backplate needs to be welded, you may need a heating table or a heat gun. I used a heating table to weld it. If you only have a soldering iron, you don't need to make a backplate, but it will definitely not be soldering. C8810845AA0F50B65536CF8F2579526D.jpg
Finished product photos
There are warm white and pure white filaments. In actual testing, the four warm white filaments are too warm and yellow, and the four pure white filaments are close to my fluorescent tube desk lamp. You can change the ratio of the number of filaments used according to the color temperature needs.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-03 17:59:46
