王达业
OLED display module-0.96 inch (4PIN)
product description
       The 0.96' OLED (4Pin) module uses SSD1306 as the main chip, with a pixel size of 128*64. The communication method can be SPI or IIC (default address is 0x78). The pins are fully compatible with IIC (that is, when set to IIC mode, you can only connect 4 Root wire), the default is 4-Wire SPI communication mode, self-illuminating, free viewing angle, low power consumption.
product description
  • Compatible with 3.3V or 5 V power input
  • Compatible with 3.3V or 5V IO port level
  • Communication method can choose SPI (4-Wire or 3-Wire)/IIC
Pin function table
symbol GND VCC SCL SDA
describe Ground pin Power input pin clock input Data input/response output
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-02 19:16:51
