sigma
2.4G wireless communication module-SI24R1
  • Working voltage: 1.9V~3.6V
  • IO port voltage: compatible with 3.3V/5V
  • Working frequency band: 2.4GHz ISM band
  • Control method: four-wire SPI (<=10MHz)
  • Data rate: 2Mbps/1Mbps/250Kbps
  • Receiving sensitivity: <-83dBm @2MHz
  • Maximum transmit power: 7dBm
product description
This module uses the SI24R1 chip as the core and cooperates with the onboard antenna to achieve the transmission and reception of 2.4G radio frequency signals. The two modules are used together to achieve medium and long-distance wireless communication.
Pin function table
label describe
GND、VDD Module power supply: 3.3V
THIS Chip on signal activates RX or TX mode
CSN SPI chip select signal
SCK SPI clock signal
SMOKE SPI data line: host output, slave input
MISO
SPI data line: host input, slave output
IRQ Maskable interrupt signal (active low)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:19:53
