桂花蒸
USB-TLL serial communication module-CH340C
product description
The CH340C USB to TTL module is based on the CH340C chip. It has a built-in crystal oscillator with a maximum baud rate of up to 2Mbps. The software is compatible with the CH341 driver and has over-current protection. It leads to the corresponding communication interface and power interface. The communication interface has an indicator light to indicate the work. status, stable communication and small size.
  • Full speed USB driver, compatible with USB2.0
  • Hardware full-duplex serial port, built-in transceiver buffer
  • Support baud rate 50bps~2Mbps
  • Output TTL level 3.3V, compatible with 5V IO level
Pin function table
symbol describe
TxD Serial data output port
RXD Serial data input port
GND Ground pin
3V3 3.3V power output pin (up to 250mA)
5V 5V power output pin (up to 500mA)
RTS MODEM contact output signal, request to send
DTR MODEM contact output signal, data terminal is ready
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 22:54:34
