3228
Serial to Ethernet module-CH9121
product description
This module implements bidirectional transmission of TTL level serial port data to Ethernet. Internally integrated TCP/IP protocol stack, with 4 working modes: TCP client, TCP server, UDP client, and UDP server. It can be easily configured through the host computer software or serial port commands, which is convenient and fast. It is a quick channel for ordinary microcontrollers, PLCs and other equipment to access the Internet.
Pin function table
symbol describe symbol describe
DIR 485 Transceiver switching +5V 5V power supply
RXD2 Serial input 2 +3.3V 3.3V power supply
TXD2 Serial output 2 RSTI Low level reset input
RXD1 Serial input 1 TCPS Connection status indication
TXD1 Serial output 1 CFG0 Mode settings
GND Common ground RESET reset
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-27 17:39:10
