toothache
EEPROM memory module-24C02
product description
  • This EEPROM module takes the M24C02 chip as the core and is used to save data during power-off. The working voltage is compatible with 3.3V and 5V systems, and is compatible with 100/400kHz IIC bus communication.
  • This module leads out the address interface A0/A1/A2 of M24C02. Users can change the bus address of 24C02 by configuring Ax, and mount up to 8 modules on the bus to achieve larger capacity data storage.
  • This module leads out the write enable port, and the user can enable or disable the write operation of 24C02 by controlling the WC# port.
product description
  • Working voltage: 2.5V ~ 5.5V
  • Storage Array: 2 Kbit (256 Byte)
  • Communication method: IIC (100kHz / 400kHz)
  • Writing time: <5ms
  • Number of writes: >4000,000 times
  • Data Storage: >200 years
Pin function table
symbol describe
GND land
VCC Power supply voltage: 2.5V~5.5V
SCL
During IIC communication, the clock signal input terminal driven by the host
Note: 24C02 always acts as a slave and receives the SCL signal.
SDA
During IIC communication, receive data input/send data output terminal
Note: 24C02 can be used as both a transmitter and a receiver
WC丨VCC Write operation enable terminal WC#: low level enables write operation
A0丨VCC 24C02 The low-order address setting end of the three-digit address
A1丨VCC 24C02 The middle address setting end of the three-digit address
A2丨VCC 24C02 The high-order address setting end of the three-digit address
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 11:11:31
