黄土马家
USB-TTL serial communication module-PL2303HXD
product description
    The PL2303HXD USB to TTL module is based on the PL2303HXD chip. It has its own crystal oscillator and 5V to 3.3V voltage regulator. The maximum baud rate can reach 12Mbps. It has over-current protection and leads to the corresponding communication interface and power interface. The communication interface has instructions. The light indicates the working status, the communication is stable, and the size is small.
  • Fully compliant with USB2.0 specification (Full-Speed)
  • Hardware full-duplex serial port, built-in transceiver buffer
  • Support baud rate 75bps~12Mbps
  • Output TTL level 3.3V, compatible with 5V IO level
Pin function table
symbol describe
TxD Serial data output port
RXD Serial data input port
GND Ground pin
3V3 3.3V power output pin (load not recommended)
5V 5V power output pin (up to 500mA)
P3 Exported functional interface
P4 Exported functional interface
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 14:23:29
