张三叔
DAPlink emulator
product description
The CMSIS-DAP module is based on the STM32F103C8T6 chip and has CMSIS-DAP firmware inside. It can be used for downloading & simulation debugging of core devices such as Cortex-M0/M1/M2/M3/M4/M7 and has a virtual serial port function. To download the program, you only need to connect 4 wires: GND, RST, SWDIO, SWCLK.
  • Support Crotex core chip
  • Support SW download method
  • With virtual serial port function
  • Can be downloaded and simulated online
Pin function table
symbol SWDIO SWCLK GND 3V3 RST RXD TxD
describe data pin clock pin Ground pin 3.3V power output pin reset pin Serial data receiving pin Serial data sending pin
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 02:06:08
  • Problems with porting cs8900 driver to s3c2410
  • Learning simulation + "Operational Amplifier Noise Optimization Handbook" reading notes NO.3
  • ICT Testing SMT
  • Does Cortex M3 support double data type?
  • Is there any sensor or circuit solution to detect static current?
  • CC2500 crash problem
