走马观花
Bluetooth device lithium battery charging module
It adopts TP4056 charging chip, which is of good quality. It has controllable step-down voltage stabilization. It has a charging indicator light. Ordinary 3mm lamp beads on the market can be used. It does not have overcharge and over-discharge protection circuits, because most batteries have protective plates. Repeat, the charging interface can be separated and placed at will, giving you more options when using your device!
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 01:51:26
  • 430 serial port problem, please advise
  • Autonomous navigation chassis
  • Hi3518 Rebirth (Part 3) http+mjpeg bug fix in minihttp
  • Problem choosing direction? I’m in a hurry!!
  • Main technical indicators of the antenna
  • Prepare MCU 12864 Dynamic waveform display Original personal test
