fish001
[Debugging] An alarm clock that can record and play sounds
Function:
  1. Brightness adjustment: You can adjust the brightness of the digital tube at will
  2. ISD1820 sound recording and playback module: can automatically play the recorded sound after reaching the point
  3. Intelligent testing to prevent snooze: Don’t even think about turning off the alarm clock until you complete the test (the plan is undecided)
  4. Top/bottom three-dimensional design: can remain upright without a shell, more beautiful and full of technology (the plan is not yet determined)
  5. Lithium battery power supply/digital tube automatic blanking: longer battery life and more environmentally friendly
  6. DS1302 clock chip: more accurate running time, continuous running time after power failure
  7. Six-digit digital tube: accurate to the second, which can ensure the accuracy of time and display more and richer content.
  8. TM1637 drives the digital tube: saving more IO ports for the microcontroller
Current issues: None
Possible reasons: None
Solution: None
Current schematic design progress: 100%
Current PCB design progress: 100%
Current code design progress: 100%
Current PCB welding progress: 0%
The recording duration depends on the "K" value of R9. “K” value refers to the table below
"K"(KΩ) Recording time(s) Sampling frequency (KHz) Typical bandwidth (KHz)
80 8 8.0 3.4
100 10 6.4 2.6
120 12 5.3 2.3
160 16 4.0 1.7
200 20 3.2 1.3
Instructions:
  1. Watch the "Usage Tutorial.mp4" in the attachment
The embodiment of power saving function:
  1. When jumper J1 shorts "1" and "2", since the RECLED terminal is at high level, the microphone has no voltage and current, and the power consumption of the entire circuit is almost zero. QQ screenshot 20210214210207.pngQQ screenshot 20210214210228.png
  2. After the system is inactive for a period of time, the digital tube will not display the seconds at first, saving the power of the two digital tubes. If the system is still inactive, the digital tube will not display the time, leaving only a dot that flashes as time passes. At this time, electric energy is saved to the extreme. (See lines 340-386 of code)
The program and library files have been placed in the attachment. Please download and use them yourself.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 21:12:13
  • Testing of heating power of NOx sensor
  • IoT access terminal
  • Please help me find out what is wrong with my program?
  • EEWORLD University ---- CC1120 Sub1G Development Kit Hands-on Practice
  • Renesas Forum started promoting easy-to-use MCUs in 2005
  • Help: Infrared sensor lamp production
