ghaytweyhtoo
STC8A8K64S4A12 LQFP64 development board
STC8A8K64 LQFP64 The difference between the integrated serial port minimum system using typec interface and other minimum systems
  • Reverse connection protection
  • Integrated serial port without compromise
  • Using typeC interface for power supply and programming, supports forward and reverse insertion   (Don’t use mini, micro, typeb if it’s 0202)
  • Ultra-low cost implementation of two-way DAC
  • External 431 reference, supports jumper switch to 2.5V or 3.3V reference
  • Onboard GND VCC SCL SDA interface OLED plug and play
  • Using 3225 package 32MHz high-speed crystal oscillator, taking into account both size and cost.(8M is too expensive)
  • TX RX independent indicator light.
  • There are 3 LEDs and two buttons on the board, and KEY1 is connected to an external interrupt.
  • One-click power-on of the entire board
  • Self-created TI style library function support (currently the writing of clock configuration GPIO serial port has been completed)
  • 32MHz current is less than 15ma
The board has been verified and the bugs in the first version have been fixed.
B station column link         https://www.bilibili.com/read/cv5697462 video introduction link        https://www.bilibili.com/video/BV15C4y1x7rL/ There is no washing water at home, it looks dirty
style reference
int main()
    SysClockSet(SYSCTL_OSC_EXT|SYSCTL_SYSDIV_1);
    GPIOConfigSet(GPIO_PORT0_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    GPIOConfigSet(GPIO_PORT1_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    GPIOConfigSet(GPIO_PORT2_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    GPIOConfigSet(GPIO_PORT3_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    GPIOConfigSet(GPIO_PORT4_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    GPIOConfigSet(GPIO_PORT5_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    GPIOConfigSet(GPIO_PORT6_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    GPIOConfigSet(GPIO_PORT7_BASE,GPIO_PIN_ALL,GPIO_PIN_TYPE_OUT_OD,true);
    while(1)
        DelayMs(1000);
        P0=0x00;
        P1=0x00;
        P2=0x00;
        P3=0x00;
        P4=0x00;
        P5=0x00;
        P6=0x00;
        P7=0x00;
        DelayMs(1000);
        P0=0xff;
        P1=0xff;
        P2=0xff;
        P3=0xff;
        P4=0xff;
        P5=0xff;
        P6=0xff;
        P7=0xff;
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 03:09:38
