宋元浩
【ART-Pi】ART PI ZIGBEE and LORA gateway expansion board
Function
1. It is equipped with a ZIGBEE module and cooperates with the WIFI module of the ART PI base plate to implement the ZIGBEE gateway;
2. It is equipped with a LORA module and cooperates with the WIFI module to implement the LORA gateway;
3. BC20 can communicate with Huawei Cloud, and can view the positioning location in real time on PC and mobile phones; the positioning principle is GPS + Beidou; the communication with Huawei Cloud uses NBIoT technology .
4. You can turn on/off the above modules through software.
hardware
1. ZIGBEE module, with all functional ports lead out, can realize ZIGBEE learning and application; communicate with ART PI through the serial port;
2. LORA module, with all functional ports lead out, can realize LORA learning and application; communicate with ART PI through SPI;
3. Equipped with BC20, with positioning function ;
4. IP5306 battery charging and discharging circuit realizes battery charging and discharging and battery power checking.
Port occupancy and functions
Ports occupied by ZIGBEE:
1. Serial port (USART2), PA2 (USART2_TX), PA3 (USART2_RX);
2. Reset control (RESET), PH3;
3. Working mode (AT/HEX) control, PH2;
4. Power control (ZIGBEE), PA6;
LORA occupied ports:
1. SPI4, PE2 (SPI4_SCK), PE4 (SPI4_NSS), PE5 (SPI4_MISO), PE6 (SPI4_MOSI);
2. Reset control (RST), PA7;
3. Transmitting and receiving status (RXTX), PC4;
4. Transmit enable (TXEN), PG14;
5. Receive enable (RXEN), PA0_C;
6. Power control (LORA), PA1_C;
BC20 occupied ports:
1. Serial port (USART1), PA9 (USART1_TX), PA10 (USART1_RX);
2. Reset control (NB_RST), PB1;
3. PSM control (NB_PSM), PB2;
4. Power control (NB_PWR), PB0;
Battery detection occupied port:
1. Detection enable (BAT_ADC_EN), PC2_C;
2. Detection port (BAT_ADC), PC3_C (ADC_C3).
Simulation diagram
physical effect
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 02:30:32
